Date/Time: Fri, 24 Jan 2025 20:34:26 +0000
can't connect
View Count: 857
[2019-02-01 15:17:43] |
AnnaK - Posts: 10 |
HI, I'm getting this message: "Windows error code 10061: no connection could be made because the target machine actively refused it" Please help, thanks |
[2019-02-01 15:52:55] |
AnnaK - Posts: 10 |
The issue has resolved itself by itself, thanks....
[2019-02-01 15:59:44] |
AnnaK - Posts: 10 |
I take it back, I have the same issue again, it seems to be intermittent....
[2019-02-01 16:02:54] |
We are contacting CTS about this.
