Date/Time: Fri, 24 Jan 2025 20:34:32 +0000
Drawing Object Selection problem on the charts
View Count: 708
[2019-02-01 15:06:56]
Meklon - Posts: 220
Hello support,
I just upgraded to version 1865 64-bit and no longer able to click on the drawn object to select it. In prior version if I point and click on any object drawn on the chart (i.e. trend line, rectangular, etc.) it would highlight the object and show it as selected. In this new version this no longer works.
Is this a bug or a change in the design? If this is a design change, how do I get this old functionality back so I could select the drawn object on the chart by clicking on it and it will remain selected?
Date Time Of Last Edit: 2019-02-01 15:07:35
[2019-02-01 17:04:52]
Be sure that the option for Support Left Click to Select Chart Drawings in the Tool >> Tool Settings is selected (On).
Also be sure that the option for Support Drag For Chart Drawing Creation/Modification is not selected (Off).
Date Time Of Last Edit: 2019-02-01 17:06:18
[2019-02-01 17:26:17]
Meklon - Posts: 220
Thank you Support,
The Support Drag For Chart Drawing Creation/Modification was checked and set to (On). Unchecking that did the trick!
Date Time Of Last Edit: 2019-02-01 17:26:41
