Date/Time: Fri, 24 Jan 2025 20:41:42 +0000
Suggestions about text labels on horizontal lines
View Count: 1885
[2019-02-01 11:32:14] |
User897562 - Posts: 1 |
Hello, it seems that there are no text label when one wants to create a sort of profil for the horizontal lines in the properties panel. https://gyazo.com/05c201d607b22951f38ac45ba126ebc0 This seems to be an evident useful parameter to be added as a trader will appreciate to differential its lines, not only from the width or the color but thanks to a custom text. This text could be placed above, below, at the center, on the left, on the right of any horizontal lines. Lines for peak, valleys, POC, TPO POC, Support and Resistance from different timeframes. Perhaps this feature exist so please excuse my ignorance in this case. |
[2019-02-01 14:08:53] |
User993113 - Posts: 74 |
are you looking for this? horizontal lines Chart Drawing Tools: Modify Text vPOC The Name Label and Value Label Subgraph settings also apply in this case. Volume By Price Study: Point of Control (SG2) peaks and valley The Value Label also be enabled to display the Valleys values on the chart Volume By Price Study: Volume Peaks (SG18) |
[2019-02-01 17:24:06] |
Refer to the documentation here for this: Volume By Price Study: Extension Line Labels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
