Date/Time: Sun, 24 Nov 2024 15:05:19 +0000
Deleting intraday volume and bar
View Count: 1215
[2013-11-12 17:43:59] |
TheCalmTrader - Posts: 32 |
Hello, Does anybody know how to delete certain price bars along with volume for a specified time period? For example a bar on spy at 12:00 was a very high volume bar and is now throwing my studies off I want to delete it from my chart so that I can have my studies revert to normal. Thanks |
[2013-11-12 17:58:18] |
This can be done through the Intraday data editor: http://www.sierrachart.com/index.php?l=doc/doc_IntradayDataEditor.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
