Date/Time: Fri, 24 Jan 2025 20:33:44 +0000
Quote Board not Attaching to Main Window
View Count: 1292
[2019-02-01 09:59:26]
User513662 - Posts: 90
The quote board does not seem to attach to the main window i.e. it is always in a non attached state and freely moveable to other monitors. This occurs despite using the "attach/detach window" feature. It does nothing differently i.e. it is in a permanent state of detachment.
If there any way to have it permanently attached inside the main SC window?
[2019-02-01 16:50:35]
When you attach the Quote Board it just means it is owned by the main window and it is always on top of the main Sierra Chart window. That behavior should function properly.
Just for clarification, the Attach and Detach options control whether the Quote Board is owned by the main Sierra Chart window or not.
Date Time Of Last Edit: 2019-02-01 16:51:39
[2019-02-02 00:11:37]
Ok I understand.
The reason being is I run 15 chartbooks with a quote board in each. Where I live we have a several momentary power drops per month. My laptop stays on but my extra monitors turn off. That means the SC main chart goes to the laptop screen and when the power comes back on (seconds later) and the screens come back on, SC moves back to the monitor it was on, but the quote boards stay on the laptop screen, so I have to manually move each quote board back to the screen it was on.
I can get a UPS but I wouldn't bother if the quote board function was attached in the main screen.
Is there another way around it that I am not seeing?
