Date/Time: Fri, 24 Jan 2025 20:33:15 +0000
[Programming Help] - Chart shortcut menu - study settings
View Count: 685
[2019-02-01 08:50:04] |
User403598 - Posts: 15 |
1) There is no possibility to delete "study settings" and "Delete and download data". Is that intentionally? 2) There is no possibility to change position of "study setting" 3) If you "place" study setting field on the top, then shortcut menu will be placed at bottom of trade menu. |
[2019-02-01 17:48:02] |
1. Yes 2. Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-01 19:13:14] |
The same time I can move (change position) “delete and download data» option. It looks ridiculous for user, sorry.
