Date/Time: Fri, 24 Jan 2025 20:37:06 +0000
Failed OCO order
View Count: 698
[2019-01-31 22:27:28] |
User116783 - Posts: 84 |
I executed a simple bracket OCO order via the DOM with a stop-limit for entry, a limit order for profit target, and two stops for stop-loss. The objective is to take half off the position once I reach the profit target so that I will break even if price then moves against me. Once the order filled, I went to go run some errands, and kept my computer running along with sierra chart. When I returned, I saw that my stops had been triggered, and my position had been closed. However my limit order was still active, even though my stops had been hit. I'm including pictures of the DOM showing what my trade/attached orders look like as well as my fills directly from BitMEX. ZS Date Time Of Last Edit: 2019-01-31 23:23:56
attached_orders.PNG / V - Attached On 2019-01-31 22:33:28 UTC - Size: 47.52 KB - 343 views bitmex fills.PNG / V - Attached On 2019-01-31 22:33:37 UTC - Size: 256.2 KB - 295 views |
[2019-02-01 03:04:15] |
A quick look at this does not look like anything unusual to us: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=25630 The parent order still visible did not fill so its attached orders are inactive. Anyway, refer to: Trade Activity Log Analysis: Support Assisted Trade Activity Log Analysis Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-01 03:05:17
