Date/Time: Fri, 24 Jan 2025 20:27:16 +0000
Export Chart data in microseconds
View Count: 768
[2019-01-31 22:19:14] |
User465507 - Posts: 74 |
I'm using the 'Write Bar Data to File' study and exporting Bitmex data to an excel sheet. I'm trying to get it down to microseconds or even ticks, is that possible? Right now using a tick chart I've got the excel file in '1 second' intervals.
[2019-02-01 03:00:59] |
Currently Sierra Chart timestamps data to the second. Millisecond time stamping is being worked on. You need to set the chart bars to 1 Trade per bar, then you will have the tick by tick data. Refer to: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TimePeriodPerBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-01 03:01:51
