Date/Time: Fri, 24 Jan 2025 19:38:46 +0000
Files (chartbooks) to automatically open at startup is limited to 40
View Count: 1209
[2019-01-31 11:41:39] |
User639658 - Posts: 2 |
The number of files or chartbooks to automatically open at startup is limited to 40. I do not want to have to open another instance of SC as i need all chartbooks on the one platform. I also would rather not manually add the other 13 chartbook files which i need to have opened as it's very time consuming and repetitive. Would you please consider increasing the number of files to automatically open at startup? |
[2019-01-31 15:48:57] |
Sierra Chart - Max - Posts: 5779 |
You can add all of your 53 chartbooks into a group. This will allow you to open all the chartbooks within a group with a single command. Refer to the Creating a Chartbook Group section here: Chartbooks (Workspaces): Creating a Chartbook Group And to the To Open a Chartbook Group section here: Chartbooks (Workspaces): To Open a Chartbook Group Sierra Chart Support Date Time Of Last Edit: 2019-01-31 15:50:17
[2019-01-31 18:39:51] |
Thank you so much. it worked perfectly!
[2019-01-31 19:38:33] |
For Chartbook Groups make sure you are using the latest prerelease which is 1866.
