Date/Time: Fri, 24 Jan 2025 20:01:20 +0000
Delete drawings
View Count: 1673
[2019-01-30 23:53:07] |
User459170 - Posts: 262 |
For some reason, choosing Tools/Manage chart drawings/Drawing Type: all/ then selecting all the drawings and DELETE doesnt seem to delete all of my drawing, there are still some left overs, what could be the reason? Thanks.
[2019-01-31 18:58:02] |
Assuming that you have scrolled all the way down and selected all the drawings, then the most likely reason that there are still drawings showing on the chart is that you have drawings that are being copied from another chart. Those drawings do not display in the Manage Chart Drawings window for the particular chart from which it is opened. Refer to the following regarding copied Chart Drawings: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-01 02:33:46] |
Rrrracer - Posts: 20 |
Selecting more than one drawing and pressing delete causes SC to crash on my machine. Also, the drop down menu only shows two symbols at a time; this particular chart has four, the others can be accessed by scrolling down but it seems a bit odd to only show two. |
Capture.PNG / V - Attached On 2019-02-01 02:30:43 UTC - Size: 83.71 KB - 304 views Attachment Deleted. |
[2019-02-01 02:38:06] |
In response to post #4, update to the current version of Sierra Chart following the instructions here: Software Download: Fast Update And the drop down list has been made with greater height in the latest prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
