Date/Time: Fri, 24 Jan 2025 19:35:50 +0000
Multiple signals, same bar
View Count: 658
[2019-01-30 19:59:48]
chart_warrior - Posts: 96
Is it possible to somehow show more than one signal under/over a bar?
For example if I have more than one then I will only be able to see one of them, whichever one is in front and the other one is hidden behind.
What would be nice if it would be possible to have them stacked or maybe some other way.
Specifically I'm talking about "point on low/high".
[2019-01-31 14:24:15]
Anyone?
[2019-01-31 16:51:50]
Figured it out.
In case anyone is interested:
Set "Output when condition true" to "user input data"
Set "Draw Style" to anything other than "point on high/low" or "color bar"
Change "Draw style percentage/ticks Offset" to whatever you want (+/- any number)
[2019-01-31 19:07:23]
Yes that does make sense but we did not know what study you were referring to in the first post.
