Date/Time: Fri, 24 Jan 2025 19:51:10 +0000
New User
View Count: 613
[2019-01-30 18:50:15] |
Kimber - Posts: 1 |
Hi, I'm a new user in the trial period and would like to check out the DOM charts. I put $15 in credit because I thought I read that a one day trial is $5, but now I don't see how to activate it. Please help
[2019-01-30 19:34:56] |
Your Sierra Chart account is not restricted. If you want to activate the Sierra Chart Real-Time and Historical Exchange Data Feed "Up to 2 Week Trial for 5 USD", you need to follow the instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions We would recommend that you do this at the start of February (Chicago time), as you would then be able to take advantage of 2 weeks of the feed vs 1 day. Before proceeding read the following: What futures trading/brokerage service do you use? For the reason why we ask this question, refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#UnderstandingAccessingDataFromCME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-30 19:36:30
