Date/Time: Fri, 24 Jan 2025 19:45:49 +0000
Unable to connect to tdameritrade for data
View Count: 1856
[2019-01-30 18:31:09]
strykerr - Posts: 14
My broker is tdameritrade.
I have selected Service provider's name in the Data/Trade Service Settings window and I have added streamer-ext-bin-tx.tdameritrade.com in the Streamer Override box.
Here is the error message:
TD Ameritrade | Connecting. | 2019-01-30 09:57:59
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-30 09:57:59
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-30 09:57:59
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-30 09:57:59
TD Ameritrade | Login Error: Login Failed | 2019-01-30 09:57:59 *
TD Ameritrade | Login failed. | 2019-01-30 09:57:59 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-30 09:57:59
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-30 09:57:59
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-30 09:57:59
Thank you
[2019-02-01 02:28:05]
We do not know the reason for this. It is TD Ameritrade indicating Login Failed. We can only suggest to verify the username and password you are using in Global Settings >> Data/Trade Service Settings .
Contact TD Ameritrade for further help.
Date Time Of Last Edit: 2019-02-02 20:41:12
