Date/Time: Fri, 24 Jan 2025 19:45:41 +0000
Include Sat/Sun bars for Daily Charts
View Count: 687
[2019-01-30 17:57:58]
User28682 - Posts: 233
On the advanced Setting tab, there is a box for:
Does this actually add blank days on ones daily chart for the weekends? I did enable it but
didn't see any change on my daily chart. In my question 2 posts ago, I asked if one could have all the days in a calendar month on a chart...this could solve this issue if it works.
Thanks!
Tom
[2019-01-31 17:13:24]
John - SC Support - Posts: 37472
You also need to have the option for Include Columns With No Data enabled in order to have this work. This is explained here:
Chart Settings: Include Saturday-Sunday Bars For Daily Charts (Chart >> Chart Settings >> Bar Period >> Chart Bar Settings menu)
Here is the information on the option for Include Columns With No Data:
Chart Settings: Include Columns With No Data (Chart >> Chart Settings >> Bar Period >> Chart Bar Settings menu)
