Date/Time: Wed, 29 Jan 2025 06:05:57 +0000
[User Discussion] - Exclude Label (Do I not get my request/questions answered because I am with Infinity?) Thanks
View Count: 843
[2019-01-30 16:03:57] |
User731023 - Posts: 138 |
Is there a way to exclude the label portion? Thank you, |
[2019-02-04 20:16:25] |
If you get a minute please.
[2019-02-07 11:50:12] |
If you get a minute, please. Why would it matter? It would eliminate overlap at times. Thank you, Second snapshot enclosed. |
Attachment Deleted. |
[2019-02-11 19:56:22] |
There is no answer because when you mark this as Programming Help, this is a thread that we will not monitor. No there is not a way to remove that label. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-11 19:57:17
[2019-03-11 00:19:01] |
Please, please, please re-consider "Omit Label Prefixes" for VbP. It is an option in Zig Zag. (As shown in snapshot) Thank you. |
[2019-03-11 17:50:40] |
Ok we will add this.
