Date/Time: Fri, 24 Jan 2025 19:52:59 +0000
zoom in and out
View Count: 1864
[2019-01-30 09:59:33] |
User877878 - Posts: 2 |
hi, how do i zoom in and out, i have no scroll mouse , i use a laptop thank u
[2019-01-30 12:01:16] |
User75002 - Posts: 117 |
You can use your up/down arrow keys or click and drag on the time axis.
[2019-01-30 19:58:51] |
Refer to: Working With Charts: Zooming In and Out Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
