Date/Time: Fri, 24 Jan 2025 19:51:15 +0000
Computer Destroyed and need to Move Sierra
View Count: 1094
[2019-01-30 03:29:35]
User417302 - Posts: 67
Recently I had a flood and my computer was destroyed. Fortunately, I can still access the data on my old hard drives. Since I just finished my new build I’m going to be moving all the files from the old drives into the new ones. How can I move my current Sierra files and settings without having to rebuild everything from scratch. I spent so much time getting everything just right and the settings perfect for me that I don’t want to have to spend hours and hours getting everything back to the way it was on the old hard drives.
Thanks,
[2019-01-30 04:07:30]
trad - Posts: 43
just copy sierra's folder over to the new drive.
it is that simple.
Date Time Of Last Edit: 2019-01-30 04:07:45
[2019-01-30 15:57:48]
Sierra Chart - Max - Posts: 5779
As the other user said you just need to copy over the SierraChart folder.
For more details, refer to the Simple Transfer/Copy of Sierra Chart Installation to Another Folder or Computer System section here:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Simple Transfer/Copy of Sierra Chart Installation to Another Folder or Computer System
Sierra Chart Support
[2019-01-30 16:57:09]
Ok great thank you, I will try that and hopefully it works. Thanks again
[2019-01-30 19:40:46]
Yes you should have no problem with this.
