Date/Time: Fri, 24 Jan 2025 18:18:07 +0000
Table of indicator values
View Count: 940
[2019-01-29 18:44:12]
DaxTrader54 - Posts: 8
Hello guys, I am looking to build a simple indicator table which I can use to display, at a glance, various indicator readings from a particular market. Something like this:
https://i.imgur.com/6uLtC1z.png
Using MetaTrader4 I had to create a custom solution (MQL to SQL to PHP and then display it live on a website) but it just seemed overkill. I am wondering if there is any built-in functionality/study that can help me achieve this.
Perhaps a way of exporting the data live and appending it to a google sheets spreadsheet or something similar?
Any assistance would be greatly appreciated.
Regards
[2019-01-29 20:24:43]
Have a look at the Study Summary window:
Study Summary Window
