Date/Time: Fri, 24 Jan 2025 18:18:07 +0000
Advanced Custom studies editor - location error
View Count: 632
[2019-01-29 16:18:50]
User968625 - Posts: 260
I am trying to start making my own indicator however I get an error for the editor location. I have sierra charts located in G Drive, separate drive for SC, and the error is because it is trying to locate it in C drive. how can I change the location path for the editor? (I see the error message that it is trying to find it C:\SierraChart\NP\notepad++.exe. it is in G drive)
[2019-01-29 17:59:49]
John - SC Support - Posts: 37466
Within Sierra Chart select Analysis >> Build Custom Studies DLL. On the window that opens select File >> Select Editor. Then select the notepad++.exe file from your G: drive installation of Sierra Chart.
