Date/Time: Fri, 24 Jan 2025 18:38:13 +0000
Study bar close
View Count: 1200
[2019-01-29 14:47:08] |
User982736 - Posts: 46 |
How can I get my studies, including my custom studies, to only calculate on bar close?
[2019-01-29 19:16:46] |
This is not supported for Sierra Chart built-in studies but for your own study, refer to this function: sc.GetBarHasClosedStatus() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
