Date/Time: Fri, 24 Jan 2025 18:17:11 +0000
sharing drawing across instances
View Count: 726
[2019-01-29 11:15:37] |
trad - Posts: 43 |
Answer might be no I reckon, but I gotta ask. Is it possible to share chart drawing across instances or multiple installation? |
[2019-01-29 14:40:50] |
No, this is not supported.
