Date/Time: Fri, 24 Jan 2025 18:22:50 +0000
Extending rectangle issue
View Count: 1173
[2019-01-29 07:27:58] |
Rassitude - Posts: 33 |
When trying to draw an extending rectangle, I get a line on the first part of the chart I click but there is no folloz through i.e. it does not extend the area but just disappear.It used to work fine but impossible to do now. Any idea? Thanks |
[2019-01-29 15:16:19] |
Seems to be specific to my chartbook..Strange
[2019-01-29 18:39:07] |
First, log into this Support Board with your active account by using Help >> Support Board and then post here when done. The problem could be because of out of order timestamps: Out of Order Timestamps Detected Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-29 18:39:36
