Date/Time: Fri, 24 Jan 2025 18:24:22 +0000
[Programming Help] - zigzag coloring based on confirmed volume
View Count: 634
[2019-01-29 02:01:39] |
User175327 - Posts: 36 |
Hi, Is there a way to use an absolute value for the "color zig-zag line using" when the volume is set to "ask bid volume difference" for "confirmed volume" and "trend confirmed volume"? This would be much more beneficial because as of now the study only draws the zig-zag line the secondary(down) color when it has positive delta in a down wave and that wave has greater volume then the prior wave. Example: up zig-zag wave has 350 delta and the down wave has -500 delta, the down wave is still colored the primary (up wave) color because -500 is less then 350.....anyway to use the absolute value instead? |
