Date/Time: Sun, 24 Nov 2024 16:54:35 +0000
#NUM! Values in $J$31, $J32$ Cells
View Count: 1565
[2013-11-12 10:42:41] |
ezfcharts00049 - Posts: 15 |
while a playback(Jone-NOV. 2013) while $J$8 =1 I have noticed that values of #NUM! appears in cells $J$31 / $J$32 & then disappeared. please advise Thanks a lot H. Oren |
[2013-11-12 10:50:28] |
while a playback of USZ3 (Jone-NOV. 2013): $J$8 =1, it happend that the value #NUM! appears in cells $J$31 / $J$32 & then disappeared. please advise Thanks a lot H. Oren |
[2013-11-13 20:03:27] |
We will be testing this today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-11-20 00:28:43] |
Not sure why this would happen, but the next release will have a check to make sure there is not an invalid value being set into those cells.
[2013-11-20 02:34:53] |
We have considered this issue some more, and we believe that it will be resolved in the next release.
