Date/Time: Sun, 26 Jan 2025 07:24:22 +0000
Tabs are not showing up in chartbook
View Count: 974
[2019-01-28 23:21:33]
jsmanuse - Posts: 32
http://www.sierrachart.com/image.php?Image=154871758710.png
[2019-01-29 03:02:27]
This is unusual. Does restarting Sierra Chart help? We are also creating a new tab control to replace the existing ones that are there now.
We are working to get that out as soon as possible.
[2019-02-17 13:44:45]
Still having the same problem.... thought you guys might want to know. Running the most recent version... restarting the program and rebooting don't solve it. The tab does reappear when I click next to where it should be but otherwise doesn't show.
http://www.sierrachart.com/image.php?Image=1550410933185.png
[2019-02-18 16:09:47]
Are you referring to the tab at the lower left having no text on it?
[2019-02-18 19:45:25]
There are 8 tabs not showing. I just happened to select the 2nd tab from the left.
[2019-02-20 03:01:50]
Okay we have not seen this before but we are rebuilding a new tab control for Sierra Chart that does not use this Microsoft version which has its issues. We are doing our best to get that done as soon as possible.
