Date/Time: Fri, 24 Jan 2025 19:50:58 +0000
OneUP Trader / P/L Management
View Count: 1055
[2019-01-28 20:55:39] |
Wucherpfennig - Posts: 3 |
Hello everybody, I have a question. With me in the window Orders and Position not the daily loss or profit indicated. The Global Profit / Loss Management does not work either. Can that be because I have an account with OneUp Trader? Thanks Jan |
[2019-01-29 03:08:48] |
There was a problem in some recent versions with the Global Profit/Loss Management but this has now been resolved in version 1865. It relies on the Net Profit/Loss calculation in charts. You will need to make sure that those calculations are coming out correct on the Trade Stats for Charts tab: Trade Activity Log: Trade Statistics for Charts (Chart Stats) Tab The documentation explains what to do if there is any problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-29 03:10:16
[2019-01-29 13:37:19] |
Hello everybody, Unfortunately, he still shows me no daily loss ?? Can you help me again? Thanks Jan |
Sierra PL.PNG / V - Attached On 2019-01-29 08:16:39 UTC - Size: 41 KB - 333 views Attachment Deleted. |
[2019-01-29 20:54:27] |
Where there trades during the trading day at the time of that screenshot, for those symbols and was Sierra Chart connected to the data feed at the same time? Here is the relevant documentation for this: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-31 17:38:00] |
Hello everybody, I still need your help. The daily loss is now in P / L management but it does not close the positions even though the daily loss is over. Have a look at the screenshot !!! Thanks Jan |
Attachment Deleted. Daily Loss.PNG / V - Attached On 2019-01-31 17:37:09 UTC - Size: 42.25 KB - 300 views |
[2019-01-31 19:40:04] |
Make the Loss Trigger Value a negative number. That is the problem.
