Date/Time: Fri, 24 Jan 2025 14:44:34 +0000
Cannot connect
View Count: 589
[2019-01-28 19:16:01] |
User486666 - Posts: 7 |
Hi there I have problem to connect with my data I have come up. Erro connections with non-affiliated broker is not allowed |
[2019-01-28 21:29:46] |
Based on the error message you are getting, you will need to use a direct account: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
