Date/Time: Fri, 24 Jan 2025 14:44:34 +0000
Time and Sales window doesn't change colors
View Count: 1453
[2019-01-28 17:33:04]
User351605 - Posts: 82
if I change the colors of the Time and Sales window in Global Settings => Graphic Settings global, nothing happens.
I tried the following: Open a new T&S window, save the settings and re-open chartbook.
Could you please let me know what might be the problem ?
[2019-01-28 22:07:44]
The most likely reason is that you are using Chart specific settings and would need to change the Time and Sales Graphics settings under Chart >> Graphics Settings - Chart. Refer to the following for more information:
Graphics Settings: Use Global Graphics Settings Instead of These Settings
Another possible, but less likely issue is that you have set the Highlights and Alerts fields for the Time and Sales Window such that those are the only colors that you are seeing. For more information, refer to the following:
Time and Sales Window: Settings Menu
Date Time Of Last Edit: 2019-01-28 22:08:31
