Date/Time: Fri, 24 Jan 2025 14:36:47 +0000
Footprint chart
View Count: 2809
[2019-01-28 16:16:19] |
User425882 - Posts: 1 |
I'm still on my 14 day trial period on SC. After navigating your software, I just can't seem to locate where the footprint chart is. Your support will be highly appreciated.
[2019-01-28 17:26:45] |
Refer to the Numbers Bars documentation here: Numbers Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
