Date/Time: Fri, 24 Jan 2025 14:52:21 +0000
[User Discussion] - depth of the market is limited to 10 levels
View Count: 597
[2019-01-28 15:54:14] |
AndreyPoroshin - Posts: 104 |
Hello, I recently use the platform and I have a couple of questions. 1. The depth of the market is limited to 10 levels of price up and 10 down. on es. The settings are set to 0. Why only 10? In other platforms, my CQG passes me 15-20. 2. Is it possible to buy package 5 directly from you with connection to CQG, staying with an AMP broker, and is there any advantage for me in terms of cost and quality? |
[2019-01-28 19:37:45] |
1. We cannot answer your question. We do not know. For 50 levels of depth use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed 2. Yes you can do this. You will have access to the full functionality of Sierra Chart and a lower price for the Sierra Chart Exchange Data Feed. Refer to: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-28 19:38:43
