Date/Time: Fri, 24 Jan 2025 14:49:32 +0000
Massage Log / problems with the CTS Data frpm TopStepTrader
View Count: 608
[2019-01-28 15:23:30]
User951805 - Posts: 3
HTTPS www.sierrachart.com:443 (2) | Creating socket. Using TLS 1.2. | 2019-01-28 14:40:33
HTTPS www.sierrachart.com:443 (2) | Connecting to IP: 46.4.97.203. | 2019-01-28 14:40:33
Reading Internal Order ID file. | 2019-01-28 14:40:33
Reading Trade Orders file. | 2019-01-28 14:40:33
Reading Trade Positions file. | 2019-01-28 14:40:33
Account Balance file. | 2019-01-28 14:40:33
Listening on UDP port 22904. | 2019-01-28 14:40:34
Software version: 1857 64-bit | 2019-01-28 14:40:34
Usage end date: 2019-06-10 | 2019-01-28 14:40:34
Enabled for: Advanced Features. | 2019-01-28 14:40:34
Enabled for: Advanced Features 2. | 2019-01-28 14:40:34
Enabled for: Sierra Chart Historical Data Service. | 2019-01-28 14:40:34
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-01-28 14:40:34
Current selected Data/Trading service: GAIN Capital/OEC | 2019-01-28 14:40:34
Chart Update Interval: 500 | 2019-01-28 14:40:34
Time Zone: +00:00:00 (UTC+00) | 2019-01-28 14:40:34
2019-01-28 08:40:33 Local computer time | 2019-01-28 14:40:34
2019-01-28 14:40:33 Local computer time in UTC | 2019-01-28 14:40:34
2019-01-28 14:40:33 Local computer time in SC Time Zone | 2019-01-28 14:40:34
2019-01-28 14:36:16 Server time in UTC | 2019-01-28 14:40:34
Local computer UTC time and Server UTC time difference: 256 seconds. | 2019-01-28 14:40:34
Notice: Your computer's clock is off by 256 seconds. For help with this, press the 'Send for Analysis' button. | 2019-01-28 14:40:34
Program path: C:\SierraChart\ | 2019-01-28 14:40:34
Data Files path: C:\SierraChart\Data\ | 2019-01-28 14:40:34
OS Version Number: 10.0 | 2019-01-28 14:40:34
Locale Setting: C | 2019-01-28 14:40:34
DLLs: sst_bands.dll, sst_bands_64.dll, sst_draw_imbalance.dll, sst_draw_imbalance_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-01-28 14:40:34
Created the DTC Protocol server. | 2019-01-28 14:40:34
DTC Protocol Server listening on port 11099. | 2019-01-28 14:40:34
Created the DTC Protocol historical data server. | 2019-01-28 14:40:34
HD Server Manager | Listening on port 11098 | 2019-01-28 14:40:34
HTTPS www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2019-01-28 14:40:34
HTTPS www.sierrachart.com:443 (4) | Connecting to IP: 46.4.97.203. | 2019-01-28 14:40:34
Checking for new symbol settings. Requested symbol settings MD5 for service code oec. Request ID: 1. | 2019-01-28 14:40:34
Received 5 login tokens. | 2019-01-28 14:40:34
Symbol settings MD5 received. Request ID: 1. | 2019-01-28 14:40:34
Symbol settings are up-to-date for oec. | 2019-01-28 14:40:34
HTTPS www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2019-01-28 14:40:36
HTTPS www.sierrachart.com:443 (5) | Connecting to IP: 46.4.97.203. | 2019-01-28 14:40:36
HTTPS login.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-28 14:40:38
HTTPS login.sierrachart.com:443 (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:40:38
HTTPS login.sierrachart.com:443 (1) | Signaling to core to close socket | 2019-01-28 14:40:38
HTTPS login.sierrachart.com:443 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:40:38
HTTPS login.sierrachart.com:443 (1) | Closed. | 2019-01-28 14:40:38
HTTPS www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2019-01-28 14:40:39
HTTPS www.sierrachart.com:443 (2) | Max send buffers used during socket life: 1 | 2019-01-28 14:40:39
HTTPS www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2019-01-28 14:40:39
HTTPS www.sierrachart.com:443 (2) | Signaling to core to close socket | 2019-01-28 14:40:39
HTTPS www.sierrachart.com:443 (4) | Max send buffers used during socket life: 1 | 2019-01-28 14:40:39
HTTPS www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:40:39
HTTPS www.sierrachart.com:443 (4) | Signaling to core to close socket | 2019-01-28 14:40:39
HTTPS www.sierrachart.com:443 (2) | Closed. | 2019-01-28 14:40:39
HTTPS www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:40:39
HTTPS www.sierrachart.com:443 (4) | Closed. | 2019-01-28 14:40:39
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:40:39
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-01-28 14:40:39
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.238. | 2019-01-28 14:40:39
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:40:40
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:40:40
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:40:40
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:40:40
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:40:40
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:40:40
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:40:40
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:40:40
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:40:40
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:40:40
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:40:40
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:40:40
HTTPS www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2019-01-28 14:40:41
HTTPS www.sierrachart.com:443 (5) | Max send buffers used during socket life: 1 | 2019-01-28 14:40:41
HTTPS www.sierrachart.com:443 (5) | Signaling to core to close socket | 2019-01-28 14:40:41
HTTPS www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:40:41
HTTPS www.sierrachart.com:443 (5) | Closed. | 2019-01-28 14:40:41
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:40:43
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-01-28 14:40:43
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.238. | 2019-01-28 14:40:43
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:40:43
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:40:44
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:40:44
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:40:44
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:40:44
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:40:44
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:40:44
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:40:44
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:40:44
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:40:44
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:40:44
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:40:44
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:40:47
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-01-28 14:40:47
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.238. | 2019-01-28 14:40:47
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:40:47
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:40:47
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:40:47
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:40:47
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:40:47
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:40:47
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:40:47
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:40:47
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:40:47
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:40:47
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:40:47
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:40:47
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:40:50
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-01-28 14:40:50
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.238. | 2019-01-28 14:40:50
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:40:51
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:40:51
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:40:51
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:40:51
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:40:51
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:40:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:40:51
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:40:51
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:40:51
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:40:51
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:40:51
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:40:51
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:40:54
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-01-28 14:40:54
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.238. | 2019-01-28 14:40:54
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:40:54
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:40:54
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:40:54
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:40:54
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:40:54
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:40:54
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:40:54
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:40:54
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:40:54
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:40:54
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:40:55
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:40:55
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:40:57
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-01-28 14:40:57
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.238. | 2019-01-28 14:40:58
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:40:58
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:40:58
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:40:58
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:40:58
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:40:58
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:40:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:40:58
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:40:58
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:40:58
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:40:58
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:40:58
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:40:58
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:41:01
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-01-28 14:41:01
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.238. | 2019-01-28 14:41:01
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:41:01
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:41:02
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:41:02
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:41:02
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:41:02
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:41:02
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:41:02
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:02
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:41:02
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:41:02
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:41:02
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:02
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:41:05
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-01-28 14:41:05
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.238. | 2019-01-28 14:41:05
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:41:05
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:41:05
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:41:05
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:41:05
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:41:05
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:41:05
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:41:05
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:05
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:41:05
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:41:05
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:41:05
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:05
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:41:08
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-01-28 14:41:08
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.238. | 2019-01-28 14:41:08
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:41:08
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:41:09
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:41:09
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:41:09
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:41:09
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:41:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:41:09
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:09
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:41:09
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:41:09
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:41:09
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:09
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:41:12
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-01-28 14:41:12
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.238. | 2019-01-28 14:41:12
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:41:12
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:41:12
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:41:12
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:41:12
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:41:12
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:41:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:41:12
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:12
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:41:12
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:41:12
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:41:12
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:12
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:41:15
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-01-28 14:41:15
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.238. | 2019-01-28 14:41:15
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:41:16
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:41:16
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:41:16
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:41:16
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:41:16
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:41:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:41:16
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:16
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:41:16
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:41:16
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:41:16
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:16
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:41:19
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-01-28 14:41:19
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.238. | 2019-01-28 14:41:19
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:41:19
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:41:20
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:41:20
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:41:20
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:41:20
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:41:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:41:20
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:20
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:41:20
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:41:20
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:41:20
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:20
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:41:23
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-01-28 14:41:23
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.238. | 2019-01-28 14:41:23
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:41:24
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:41:25
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:41:25
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:41:25
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:41:25
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:41:25
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:41:25
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:41:25
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:25
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:41:25
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:41:25
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:25
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:41:28
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-01-28 14:41:28
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.238. | 2019-01-28 14:41:28
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:41:28
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:41:28
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:41:28
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:41:28
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:41:28
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:41:28
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:41:28
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:41:28
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:28
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:41:28
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:41:28
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:28
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:41:31
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-01-28 14:41:31
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.238. | 2019-01-28 14:41:31
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:41:32
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:41:32
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:41:32
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:41:32
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:41:32
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:41:32
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:41:32
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:32
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:41:32
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:41:32
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:41:32
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:32
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:41:35
GAIN Capital FIX Trading socket (2) | Creating socket. | 2019-01-28 14:41:35
GAIN Capital FIX Trading socket (2) | Connecting to IP: 64.94.37.238. | 2019-01-28 14:41:35
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:41:35
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2019-01-28 14:41:35
GAIN Capital FIX Trading socket (2) | Max send buffers used during socket life: 1 | 2019-01-28 14:41:35
GAIN Capital FIX Trading socket (2) | Signaling to core to close socket | 2019-01-28 14:41:35
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:41:35
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:41:35
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:41:35
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:35
GAIN Capital FIX Trading socket (2) | Closed. | 2019-01-28 14:41:35
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:41:35
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:41:35
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:36
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:41:39
GAIN Capital FIX Trading socket (2) | Creating socket. | 2019-01-28 14:41:39
GAIN Capital FIX Trading socket (2) | Connecting to IP: 64.94.37.238. | 2019-01-28 14:41:39
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:41:39
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2019-01-28 14:41:39
GAIN Capital FIX Trading socket (2) | Max send buffers used during socket life: 1 | 2019-01-28 14:41:39
GAIN Capital FIX Trading socket (2) | Signaling to core to close socket | 2019-01-28 14:41:39
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:41:39
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:41:39
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:41:39
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:39
GAIN Capital FIX Trading socket (2) | Closed. | 2019-01-28 14:41:39
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:41:39
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:41:39
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:39
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:41:42
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-01-28 14:41:42
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.238. | 2019-01-28 14:41:42
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:41:42
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:41:42
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:41:42
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:41:42
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:41:42
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:41:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:41:42
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:42
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:41:42
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:41:42
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:41:43
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:43
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:41:46
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-01-28 14:41:46
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.37. | 2019-01-28 14:41:46
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:41:46
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:41:46
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:41:46
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:41:46
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:41:46
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:41:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:41:46
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:46
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:41:46
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:41:46
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:41:46
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:46
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:41:49
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-01-28 14:41:49
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.37. | 2019-01-28 14:41:49
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:41:49
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:41:49
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:41:49
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:41:49
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:41:49
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:41:49
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:41:49
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:49
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:41:49
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:41:49
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:41:49
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:49
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:41:52
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-01-28 14:41:52
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.37. | 2019-01-28 14:41:52
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:41:53
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:41:53
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:41:53
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:41:53
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:41:53
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:41:53
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:41:53
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:53
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:41:53
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:41:53
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:41:53
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:53
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:41:56
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-01-28 14:41:56
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.37. | 2019-01-28 14:41:56
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:41:56
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:41:56
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:41:56
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:41:56
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:41:56
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:41:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:41:56
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:56
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:41:56
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:41:56
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:41:56
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:41:56
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:41:59
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-01-28 14:41:59
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.37. | 2019-01-28 14:41:59
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:42:00
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:42:00
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:42:00
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:42:00
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:42:00
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:42:00
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:42:00
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:00
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:42:00
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:42:00
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:42:00
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:00
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:42:03
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-01-28 14:42:03
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.37. | 2019-01-28 14:42:03
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:42:03
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:42:03
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:42:03
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:42:03
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:42:03
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:42:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:42:03
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:03
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:42:03
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:42:03
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:42:03
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:03
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-01-28 14:42:06
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-01-28 14:42:06
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.37. | 2019-01-28 14:42:06
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:42:07
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:42:07
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:42:07
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:42:07
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:42:07
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:42:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:42:07
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:07
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:42:07
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:42:07
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:42:07
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:07
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-01-28 14:42:10
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-01-28 14:42:10
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2019-01-28 14:42:10
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:42:10
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:42:11
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:42:11
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:42:11
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:42:11
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:42:11
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:42:11
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:11
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:42:11
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:42:11
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:42:11
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:11
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-01-28 14:42:11
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-01-28 14:42:11
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2019-01-28 14:42:11
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:42:11
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:42:12
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:42:12
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:42:12
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:42:12
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:42:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:42:12
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:12
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:42:12
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:42:12
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:42:12
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:12
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-01-28 14:42:15
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-01-28 14:42:15
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2019-01-28 14:42:15
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:42:15
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:42:22
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:42:22
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:42:22
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:42:22
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:42:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:42:22
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:22
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:42:22
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:42:22
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:42:22
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:22
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-01-28 14:42:25
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-01-28 14:42:25
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2019-01-28 14:42:25
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:42:25
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:42:33
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:42:33
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:42:33
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:42:33
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:42:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:42:33
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:33
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:42:33
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:42:33
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:42:33
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:33
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-01-28 14:42:36
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2019-01-28 14:42:36
GAIN Capital FIX Trading socket (2) | Connecting to IP: 67.23.52.47. | 2019-01-28 14:42:36
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:42:36
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2019-01-28 14:42:36
GAIN Capital FIX Trading socket (2) | Max send buffers used during socket life: 1 | 2019-01-28 14:42:36
GAIN Capital FIX Trading socket (2) | Signaling to core to close socket | 2019-01-28 14:42:36
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:42:36
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:42:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:42:36
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:36
GAIN Capital FIX Trading socket (2) | Closed. | 2019-01-28 14:42:36
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:42:36
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:42:36
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:36
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-01-28 14:42:39
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-01-28 14:42:39
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2019-01-28 14:42:39
GAIN Capital FIX Trading: Sending the Logon message. | 2019-01-28 14:42:40
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:42:40
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:42:40
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-01-28 14:42:40
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:42:40
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:42:40
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:42:40
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:40
GAIN Capital FIX Trading socket (1) | Closed. | 2019-01-28 14:42:40
GAIN Capital/OEC | Disconnected from the trading server. | 2019-01-28 14:42:40
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:42:40
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:40
GAIN Capital/OEC | Disconnected. | 2019-01-28 14:42:41
HTTPS www.sierrachart.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-28 14:42:41
HTTPS www.sierrachart.com:443 (1) | Connecting to IP: 46.4.97.203. | 2019-01-28 14:42:41
Checking for new symbol settings. Requested symbol settings MD5 for service code cts. Request ID: 2. | 2019-01-28 14:42:41
Current selected Data/Trading service: CTS T4 FIX | 2019-01-28 14:42:41
Symbol settings MD5 received. Request ID: 2. | 2019-01-28 14:42:42
Requested symbol settings for service code cts. Request ID: 3. Overwrite = on. | 2019-01-28 14:42:42
Symbol settings received. Request ID: 3. | 2019-01-28 14:42:42
Processed 1337 symbol settings. | 2019-01-28 14:42:43
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:42:43
CTS T4 FIX | Firm: PTP | 2019-01-28 14:42:43
CTS FIX socket (2) | Creating socket. Using TLS 1.0. | 2019-01-28 14:42:46
CTS FIX socket (2) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:42:46
CTS FIX: Sending the Logon message. | 2019-01-28 14:42:46
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:42:46 *
CTS FIX socket (2) | Socket gracefully closed by remote side. | 2019-01-28 14:42:46
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:38:29.74045=1372=A373=1058=Sending Time Accuracy problem10=205 | 2019-01-28 14:42:46 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:42:46 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:38:29.74058=Received unauthorized messages while not logged in10=229 | 2019-01-28 14:42:46 *
CTS FIX socket (2) | Max send buffers used during socket life: 1 | 2019-01-28 14:42:46
CTS FIX socket (2) | Signaling to core to close socket | 2019-01-28 14:42:46
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:42:46
CTS FIX socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:42:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:42:46
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:46
CTS FIX socket (2) | Closed. | 2019-01-28 14:42:46
CTS T4 FIX | Disconnected. | 2019-01-28 14:42:46
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:46
HTTPS www.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-28 14:42:47
HTTPS www.sierrachart.com:443 (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:42:47
HTTPS www.sierrachart.com:443 (1) | Signaling to core to close socket | 2019-01-28 14:42:47
HTTPS www.sierrachart.com:443 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:42:47
HTTPS www.sierrachart.com:443 (1) | Closed. | 2019-01-28 14:42:47
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:42:49
CTS T4 FIX | Firm: PTP | 2019-01-28 14:42:49
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:42:49
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:42:49
CTS FIX: Sending the Logon message. | 2019-01-28 14:42:50
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:42:50 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:38:33.60045=1372=A373=1058=Sending Time Accuracy problem10=195 | 2019-01-28 14:42:50 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:42:50 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:38:33.60058=Received unauthorized messages while not logged in10=219 | 2019-01-28 14:42:50 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:42:50
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:42:50
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:42:50
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:42:50
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:42:50
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:42:50
CTS FIX socket (1) | Closed. | 2019-01-28 14:42:50
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:50
CTS T4 FIX | Disconnected. | 2019-01-28 14:42:50
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:50
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:42:53
CTS T4 FIX | Firm: PTP | 2019-01-28 14:42:53
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:42:53
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:42:53
CTS FIX: Sending the Logon message. | 2019-01-28 14:42:54
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:42:58 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:38:40.14945=1372=A373=1058=Sending Time Accuracy problem10=201 | 2019-01-28 14:42:58 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:42:58 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:42:58
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:38:40.14958=Received unauthorized messages while not logged in10=225 | 2019-01-28 14:42:58 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:42:58
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:42:58
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:42:58
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:42:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:42:58
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:58
CTS FIX socket (1) | Closed. | 2019-01-28 14:42:58
CTS T4 FIX | Disconnected. | 2019-01-28 14:42:58
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:42:58
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:43:01
CTS T4 FIX | Firm: PTP | 2019-01-28 14:43:01
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:43:01
CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-28 14:43:01
CTS FIX: Sending the Logon message. | 2019-01-28 14:43:01
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:43:02 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:38:45.13045=1372=A373=1058=Sending Time Accuracy problem10=196 | 2019-01-28 14:43:02 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:43:02 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:38:45.13058=Received unauthorized messages while not logged in10=220 | 2019-01-28 14:43:02 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:43:02
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:43:02
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:43:02
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:43:02
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:43:02
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:43:02
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:43:02
CTS FIX socket (1) | Closed. | 2019-01-28 14:43:02
CTS T4 FIX | Disconnected. | 2019-01-28 14:43:02
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:43:02
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:43:05
CTS T4 FIX | Firm: PTP | 2019-01-28 14:43:05
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:43:05
CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-28 14:43:05
CTS FIX: Sending the Logon message. | 2019-01-28 14:43:05
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:43:06 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:38:49.06745=1372=A373=1058=Sending Time Accuracy problem10=209 | 2019-01-28 14:43:06 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:43:06 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:43:06
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:43:06
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:43:06
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:43:06
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:43:06
CTS FIX socket (1) | Closed. | 2019-01-28 14:43:06
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:43:06
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:43:06
CTS T4 FIX | Disconnected. | 2019-01-28 14:43:06
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:43:06
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:43:09
CTS T4 FIX | Firm: PTP | 2019-01-28 14:43:09
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:43:09
CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-28 14:43:09
CTS FIX: Sending the Logon message. | 2019-01-28 14:43:09
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:43:14 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:38:56.87145=1372=A373=1058=Sending Time Accuracy problem10=210 | 2019-01-28 14:43:14 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:43:14 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:38:56.87158=Received unauthorized messages while not logged in10=234 | 2019-01-28 14:43:14 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:43:14
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:43:14
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:43:14
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:43:14
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:43:14
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:43:14
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:43:14
CTS FIX socket (1) | Closed. | 2019-01-28 14:43:14
CTS T4 FIX | Disconnected. | 2019-01-28 14:43:14
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:43:14
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:43:17
CTS T4 FIX | Firm: PTP | 2019-01-28 14:43:17
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:43:17
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:43:17
CTS FIX: Sending the Logon message. | 2019-01-28 14:43:17
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:43:23
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:43:23 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:39:06.32745=1372=A373=1058=Sending Time Accuracy problem10=202 | 2019-01-28 14:43:23 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:43:23 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:39:06.32858=Received unauthorized messages while not logged in10=227 | 2019-01-28 14:43:23 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:43:23
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:43:23
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:43:23
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:43:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:43:23
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:43:23
CTS FIX socket (1) | Closed. | 2019-01-28 14:43:23
CTS T4 FIX | Disconnected. | 2019-01-28 14:43:23
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:43:23
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:43:26
CTS T4 FIX | Firm: PTP | 2019-01-28 14:43:26
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:43:26
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:43:26
CTS FIX: Sending the Logon message. | 2019-01-28 14:43:26
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:43:27 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:39:10.10645=1372=A373=1058=Sending Time Accuracy problem10=192 | 2019-01-28 14:43:27 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:43:27 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:39:10.10758=Received unauthorized messages while not logged in10=217 | 2019-01-28 14:43:27 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:43:27
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:43:27
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:43:27
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:43:27
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:43:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:43:27
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:43:27
CTS FIX socket (1) | Closed. | 2019-01-28 14:43:27
CTS T4 FIX | Disconnected. | 2019-01-28 14:43:27
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:43:27
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:43:30
CTS T4 FIX | Firm: PTP | 2019-01-28 14:43:30
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:43:31
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:43:31
CTS FIX: Sending the Logon message. | 2019-01-28 14:43:31
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:43:31 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:39:14.74645=1372=A373=1058=Sending Time Accuracy problem10=206 | 2019-01-28 14:43:31 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:43:31 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:43:31
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:39:14.74758=Received unauthorized messages while not logged in10=231 | 2019-01-28 14:43:31 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:43:31
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:43:31
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:43:31
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:43:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:43:31
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:43:31
CTS FIX socket (1) | Closed. | 2019-01-28 14:43:31
CTS T4 FIX | Disconnected. | 2019-01-28 14:43:31
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:43:31
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:43:34
CTS T4 FIX | Firm: PTP | 2019-01-28 14:43:34
CTS FIX socket (2) | Creating socket. Using TLS 1.0. | 2019-01-28 14:43:34
CTS FIX socket (2) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:43:34
CTS FIX: Sending the Logon message. | 2019-01-28 14:43:35
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:43:35 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:39:18.57345=1372=A373=1058=Sending Time Accuracy problem10=208 | 2019-01-28 14:43:35 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:43:35 *
CTS FIX socket (2) | Socket gracefully closed by remote side. | 2019-01-28 14:43:35
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:39:18.57458=Received unauthorized messages while not logged in10=233 | 2019-01-28 14:43:35 *
CTS FIX socket (2) | Max send buffers used during socket life: 1 | 2019-01-28 14:43:35
CTS FIX socket (2) | Signaling to core to close socket | 2019-01-28 14:43:35
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:43:35
CTS FIX socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:43:35
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:43:35
CTS FIX socket (2) | Closed. | 2019-01-28 14:43:35
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:43:35
CTS T4 FIX | Disconnected. | 2019-01-28 14:43:35
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:43:35
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:43:38
CTS T4 FIX | Firm: PTP | 2019-01-28 14:43:38
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:43:38
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:43:38
CTS FIX: Sending the Logon message. | 2019-01-28 14:43:39
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:43:39 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:39:22.35745=1372=A373=1058=Sending Time Accuracy problem10=203 | 2019-01-28 14:43:39 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:43:39 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:43:39
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:39:22.35858=Received unauthorized messages while not logged in10=228 | 2019-01-28 14:43:39 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:43:39
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:43:39
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:43:39
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:43:39
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:43:39
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:43:39
CTS FIX socket (1) | Closed. | 2019-01-28 14:43:39
CTS T4 FIX | Disconnected. | 2019-01-28 14:43:39
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:43:39
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:43:42
CTS T4 FIX | Firm: PTP | 2019-01-28 14:43:42
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:43:44
CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-28 14:43:44
CTS FIX: Sending the Logon message. | 2019-01-28 14:43:45
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:43:45 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:39:28.25545=1372=A373=1058=Sending Time Accuracy problem10=206 | 2019-01-28 14:43:45 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:43:45 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:39:28.25558=Received unauthorized messages while not logged in10=230 | 2019-01-28 14:43:45 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:43:45
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:43:45
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:43:45
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:43:45
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:43:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:43:45
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:43:45
CTS FIX socket (1) | Closed. | 2019-01-28 14:43:45
CTS T4 FIX | Disconnected. | 2019-01-28 14:43:45
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:43:45
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:43:48
CTS T4 FIX | Firm: PTP | 2019-01-28 14:43:48
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:43:48
CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-28 14:43:48
CTS FIX: Sending the Logon message. | 2019-01-28 14:43:48
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:43:56 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:39:37.00445=1372=A373=1058=Sending Time Accuracy problem10=198 | 2019-01-28 14:43:56 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:43:56 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:43:56
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:39:37.00458=Received unauthorized messages while not logged in10=222 | 2019-01-28 14:43:56 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:43:56
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:43:56
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:43:56
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:43:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:43:56
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:43:56
CTS FIX socket (1) | Closed. | 2019-01-28 14:43:56
CTS T4 FIX | Disconnected. | 2019-01-28 14:43:56
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:43:56
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:43:59
CTS T4 FIX | Firm: PTP | 2019-01-28 14:43:59
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:44:00
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:44:00
CTS FIX: Sending the Logon message. | 2019-01-28 14:44:00
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:44:00 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:39:43.64145=1372=A373=1058=Sending Time Accuracy problem10=202 | 2019-01-28 14:44:00 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:44:00 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:39:43.64158=Received unauthorized messages while not logged in10=226 | 2019-01-28 14:44:00 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:44:00
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:44:00
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:44:00
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:44:00
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:44:00
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:44:00
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:00
CTS FIX socket (1) | Closed. | 2019-01-28 14:44:00
CTS T4 FIX | Disconnected. | 2019-01-28 14:44:00
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:00
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:44:03
CTS T4 FIX | Firm: PTP | 2019-01-28 14:44:03
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:44:03
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:44:03
CTS FIX: Sending the Logon message. | 2019-01-28 14:44:04
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:44:04 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:39:47.42345=1372=A373=1058=Sending Time Accuracy problem10=204 | 2019-01-28 14:44:04 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:44:04 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:39:47.42358=Received unauthorized messages while not logged in10=228 | 2019-01-28 14:44:04 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:44:04
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:44:04
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:44:04
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:44:04
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:44:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:44:04
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:04
CTS FIX socket (1) | Closed. | 2019-01-28 14:44:04
CTS T4 FIX | Disconnected. | 2019-01-28 14:44:04
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:04
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:44:07
CTS T4 FIX | Firm: PTP | 2019-01-28 14:44:07
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:44:07
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:44:07
CTS FIX: Sending the Logon message. | 2019-01-28 14:44:07
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:44:08 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:39:51.63645=1372=A373=1058=Sending Time Accuracy problem10=205 | 2019-01-28 14:44:08 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:44:08 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:44:08
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:39:51.63658=Received unauthorized messages while not logged in10=229 | 2019-01-28 14:44:08 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:44:08
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:44:08
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:44:08
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:44:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:44:08
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:08
CTS FIX socket (1) | Closed. | 2019-01-28 14:44:08
CTS T4 FIX | Disconnected. | 2019-01-28 14:44:08
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:08
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:44:11
CTS T4 FIX | Firm: PTP | 2019-01-28 14:44:11
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:44:11
CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-28 14:44:11
CTS FIX: Sending the Logon message. | 2019-01-28 14:44:12
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:44:12
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:44:12 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:39:55.72945=1372=A373=1058=Sending Time Accuracy problem10=212 | 2019-01-28 14:44:12 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:44:12 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:44:12
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:44:12
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:44:12
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:44:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:44:12
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:12
CTS FIX socket (1) | Closed. | 2019-01-28 14:44:12
CTS T4 FIX | Disconnected. | 2019-01-28 14:44:12
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:12
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:44:15
CTS T4 FIX | Firm: PTP | 2019-01-28 14:44:15
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:44:15
CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-28 14:44:15
CTS FIX: Sending the Logon message. | 2019-01-28 14:44:16
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:44:16 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:39:59.46345=1372=A373=1058=Sending Time Accuracy problem10=211 | 2019-01-28 14:44:16 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:44:16 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:44:16
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:39:59.46458=Received unauthorized messages while not logged in10=236 | 2019-01-28 14:44:16 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:44:16
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:44:16
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:44:16
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:44:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:44:16
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:16
CTS FIX socket (1) | Closed. | 2019-01-28 14:44:16
CTS T4 FIX | Disconnected. | 2019-01-28 14:44:16
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:16
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:44:19
CTS T4 FIX | Firm: PTP | 2019-01-28 14:44:19
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:44:19
CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-28 14:44:19
CTS FIX: Sending the Logon message. | 2019-01-28 14:44:20
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:44:20 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:44:20
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:40:03.20845=1372=A373=1058=Sending Time Accuracy problem10=189 | 2019-01-28 14:44:20 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:44:20 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:40:03.20858=Received unauthorized messages while not logged in10=213 | 2019-01-28 14:44:20 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:44:20
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:44:20
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:44:20
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:44:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:44:20
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:20
CTS FIX socket (1) | Closed. | 2019-01-28 14:44:20
CTS T4 FIX | Disconnected. | 2019-01-28 14:44:20
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:20
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:44:23
CTS T4 FIX | Firm: PTP | 2019-01-28 14:44:23
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:44:26
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:44:26
CTS FIX: Sending the Logon message. | 2019-01-28 14:44:26
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:44:27 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:40:09.85545=1372=A373=1058=Sending Time Accuracy problem10=203 | 2019-01-28 14:44:27 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:44:27 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:44:27
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:44:27
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:44:27
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:44:27
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:44:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:44:27
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:27
CTS FIX socket (1) | Closed. | 2019-01-28 14:44:27
CTS T4 FIX | Disconnected. | 2019-01-28 14:44:27
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:27
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:44:30
CTS T4 FIX | Firm: PTP | 2019-01-28 14:44:30
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:44:30
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:44:30
CTS FIX: Sending the Logon message. | 2019-01-28 14:44:30
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:44:31 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:40:13.90845=1372=A373=1058=Sending Time Accuracy problem10=197 | 2019-01-28 14:44:31 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:44:31 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:44:31
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:40:13.90858=Received unauthorized messages while not logged in10=221 | 2019-01-28 14:44:31 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:44:31
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:44:31
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:44:31
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:44:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:44:31
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:31
CTS FIX socket (1) | Closed. | 2019-01-28 14:44:31
CTS T4 FIX | Disconnected. | 2019-01-28 14:44:31
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:31
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:44:34
CTS T4 FIX | Firm: PTP | 2019-01-28 14:44:34
CTS FIX socket (2) | Creating socket. Using TLS 1.0. | 2019-01-28 14:44:34
CTS FIX socket (2) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:44:34
CTS FIX: Sending the Logon message. | 2019-01-28 14:44:34
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:44:34 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:40:17.68145=1372=A373=1058=Sending Time Accuracy problem10=199 | 2019-01-28 14:44:34 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:44:34 *
CTS FIX socket (2) | Socket gracefully closed by remote side. | 2019-01-28 14:44:34
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:40:17.68258=Received unauthorized messages while not logged in10=224 | 2019-01-28 14:44:34 *
CTS FIX socket (2) | Max send buffers used during socket life: 1 | 2019-01-28 14:44:34
CTS FIX socket (2) | Signaling to core to close socket | 2019-01-28 14:44:34
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:44:34
CTS FIX socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:44:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:44:34
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:34
CTS FIX socket (2) | Closed. | 2019-01-28 14:44:34
CTS T4 FIX | Disconnected. | 2019-01-28 14:44:34
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:34
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:44:37
CTS T4 FIX | Firm: PTP | 2019-01-28 14:44:37
CTS FIX socket (2) | Creating socket. Using TLS 1.0. | 2019-01-28 14:44:37
CTS FIX socket (2) | Connecting to IP: 69.44.110.200. | 2019-01-28 14:44:37
CTS FIX: Sending the Logon message. | 2019-01-28 14:44:38
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:44:38 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:40:21.68145=1372=A373=1058=Sending Time Accuracy problem10=194 | 2019-01-28 14:44:38 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:44:38 *
CTS FIX socket (2) | Socket gracefully closed by remote side. | 2019-01-28 14:44:38
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:40:21.68258=Received unauthorized messages while not logged in10=219 | 2019-01-28 14:44:38 *
CTS FIX socket (2) | Max send buffers used during socket life: 1 | 2019-01-28 14:44:38
CTS FIX socket (2) | Signaling to core to close socket | 2019-01-28 14:44:38
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:44:38
CTS FIX socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:44:38
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:44:38
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:38
CTS FIX socket (2) | Closed. | 2019-01-28 14:44:38
CTS T4 FIX | Disconnected. | 2019-01-28 14:44:38
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:38
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:44:41
CTS T4 FIX | Firm: PTP | 2019-01-28 14:44:41
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:44:42
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:44:42
CTS FIX: Sending the Logon message. | 2019-01-28 14:44:42
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:44:42 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:40:25.57045=1372=A373=1058=Sending Time Accuracy problem10=195 | 2019-01-28 14:44:42 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:44:42 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:40:25.57158=Received unauthorized messages while not logged in10=220 | 2019-01-28 14:44:42 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:44:42
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:44:42
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:44:42
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:44:42
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:44:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:44:42
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:42
CTS FIX socket (1) | Closed. | 2019-01-28 14:44:42
CTS T4 FIX | Disconnected. | 2019-01-28 14:44:42
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:42
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:44:45
CTS T4 FIX | Firm: PTP | 2019-01-28 14:44:45
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:44:45
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:44:45
CTS FIX: Sending the Logon message. | 2019-01-28 14:44:46
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:44:46 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:40:29.37245=1372=A373=1058=Sending Time Accuracy problem10=199 | 2019-01-28 14:44:46 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:44:46 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:44:46
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:40:29.37358=Received unauthorized messages while not logged in10=224 | 2019-01-28 14:44:46 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:44:46
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:44:46
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:44:46
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:44:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:44:46
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:46
CTS FIX socket (1) | Closed. | 2019-01-28 14:44:46
CTS T4 FIX | Disconnected. | 2019-01-28 14:44:46
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:46
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:44:49
CTS T4 FIX | Firm: PTP | 2019-01-28 14:44:49
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:44:49
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:44:49
CTS FIX: Sending the Logon message. | 2019-01-28 14:44:49
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:44:50 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:44:50
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:40:33.18945=1372=A373=1058=Sending Time Accuracy problem10=200 | 2019-01-28 14:44:50 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:44:50 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:40:33.19058=Received unauthorized messages while not logged in10=216 | 2019-01-28 14:44:50 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:44:50
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:44:50
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:44:50
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:44:50
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:44:50
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:50
CTS FIX socket (1) | Closed. | 2019-01-28 14:44:50
CTS T4 FIX | Disconnected. | 2019-01-28 14:44:50
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:50
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:44:53
CTS T4 FIX | Firm: PTP | 2019-01-28 14:44:53
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:44:53
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:44:53
CTS FIX: Sending the Logon message. | 2019-01-28 14:44:53
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:44:54 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:40:37.08945=1372=A373=1058=Sending Time Accuracy problem10=203 | 2019-01-28 14:44:54 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:44:54 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:44:54
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:40:37.09058=Received unauthorized messages while not logged in10=219 | 2019-01-28 14:44:54 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:44:54
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:44:54
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:44:54
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:44:54
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:44:54
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:54
CTS FIX socket (1) | Closed. | 2019-01-28 14:44:54
CTS T4 FIX | Disconnected. | 2019-01-28 14:44:54
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:54
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:44:57
CTS T4 FIX | Firm: PTP | 2019-01-28 14:44:57
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:44:57
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:44:57
CTS FIX: Sending the Logon message. | 2019-01-28 14:44:57
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:44:58 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:40:40.88945=1372=A373=1058=Sending Time Accuracy problem10=205 | 2019-01-28 14:44:58 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:44:58 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:40:40.89058=Received unauthorized messages while not logged in10=221 | 2019-01-28 14:44:58 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:44:58
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:44:58
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:44:58
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:44:58
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:44:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:44:58
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:58
CTS FIX socket (1) | Closed. | 2019-01-28 14:44:58
CTS T4 FIX | Disconnected. | 2019-01-28 14:44:58
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:44:58
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:45:01
CTS T4 FIX | Firm: PTP | 2019-01-28 14:45:01
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:45:01
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:45:01
CTS FIX: Sending the Logon message. | 2019-01-28 14:45:01
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:45:01 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:40:44.64745=1372=A373=1058=Sending Time Accuracy problem10=201 | 2019-01-28 14:45:01 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:45:01 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:45:01
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:40:44.64758=Received unauthorized messages while not logged in10=225 | 2019-01-28 14:45:01 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:45:01
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:45:01
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:45:01
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:45:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:45:01
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:01
CTS FIX socket (1) | Closed. | 2019-01-28 14:45:01
CTS T4 FIX | Disconnected. | 2019-01-28 14:45:01
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:01
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:45:04
CTS T4 FIX | Firm: PTP | 2019-01-28 14:45:04
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:45:04
CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-28 14:45:04
CTS FIX: Sending the Logon message. | 2019-01-28 14:45:05
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:45:05 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:45:05
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:40:48.49545=1372=A373=1058=Sending Time Accuracy problem10=206 | 2019-01-28 14:45:05 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:45:05 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:40:48.49558=Received unauthorized messages while not logged in10=230 | 2019-01-28 14:45:05 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:45:05
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:45:05
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:45:05
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:45:05
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:45:05
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:05
CTS FIX socket (1) | Closed. | 2019-01-28 14:45:05
CTS T4 FIX | Disconnected. | 2019-01-28 14:45:05
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:05
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:45:08
CTS T4 FIX | Firm: PTP | 2019-01-28 14:45:08
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:45:08
CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-28 14:45:08
CTS FIX: Sending the Logon message. | 2019-01-28 14:45:09
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:45:09 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:40:52.25645=1372=A373=1058=Sending Time Accuracy problem10=196 | 2019-01-28 14:45:09 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:45:09 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:40:52.25658=Received unauthorized messages while not logged in10=220 | 2019-01-28 14:45:09 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:45:09
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:45:09
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:45:09
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:45:09
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:45:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:45:09
CTS FIX socket (1) | Closed. | 2019-01-28 14:45:09
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:09
CTS T4 FIX | Disconnected. | 2019-01-28 14:45:09
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:09
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:45:12
CTS T4 FIX | Firm: PTP | 2019-01-28 14:45:12
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:45:12
CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-28 14:45:12
CTS FIX: Sending the Logon message. | 2019-01-28 14:45:12
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:45:13 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:40:56.00445=1372=A373=1058=Sending Time Accuracy problem10=191 | 2019-01-28 14:45:13 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:45:13 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:40:56.00458=Received unauthorized messages while not logged in10=215 | 2019-01-28 14:45:13 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:45:13
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:45:13
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:45:13
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:45:13
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:45:13
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:45:13
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:13
CTS FIX socket (1) | Closed. | 2019-01-28 14:45:13
CTS T4 FIX | Disconnected. | 2019-01-28 14:45:13
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:13
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:45:16
CTS T4 FIX | Firm: PTP | 2019-01-28 14:45:16
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:45:16
CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-28 14:45:16
CTS FIX: Sending the Logon message. | 2019-01-28 14:45:16
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:45:17 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:40:59.87745=1372=A373=1058=Sending Time Accuracy problem10=212 | 2019-01-28 14:45:17 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:45:17 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:45:17
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:40:59.87758=Received unauthorized messages while not logged in10=236 | 2019-01-28 14:45:17 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:45:17
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:45:17
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:45:17
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:45:17
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:45:17
CTS FIX socket (1) | Closed. | 2019-01-28 14:45:17
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:17
CTS T4 FIX | Disconnected. | 2019-01-28 14:45:17
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:17
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:45:20
CTS T4 FIX | Firm: PTP | 2019-01-28 14:45:20
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:45:20
CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-28 14:45:20
CTS FIX: Sending the Logon message. | 2019-01-28 14:45:21
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:45:21 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:41:04.22145=1372=A373=1058=Sending Time Accuracy problem10=186 | 2019-01-28 14:45:21 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:45:21 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:41:04.22158=Received unauthorized messages while not logged in10=210 | 2019-01-28 14:45:21 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:45:21
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:45:21
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:45:21
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:45:21
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:45:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:45:21
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:21
CTS FIX socket (1) | Closed. | 2019-01-28 14:45:21
CTS T4 FIX | Disconnected. | 2019-01-28 14:45:21
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:21
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:45:24
CTS T4 FIX | Firm: PTP | 2019-01-28 14:45:24
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:45:24
CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-28 14:45:24
CTS FIX: Sending the Logon message. | 2019-01-28 14:45:25
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:45:25 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:41:08.45545=1372=A373=1058=Sending Time Accuracy problem10=199 | 2019-01-28 14:45:25 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:45:25 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:45:25
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:41:08.45558=Received unauthorized messages while not logged in10=223 | 2019-01-28 14:45:25 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:45:25
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:45:25
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:45:25
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:45:25
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:45:25
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:25
CTS FIX socket (1) | Closed. | 2019-01-28 14:45:25
CTS T4 FIX | Disconnected. | 2019-01-28 14:45:25
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:25
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:45:28
CTS T4 FIX | Firm: PTP | 2019-01-28 14:45:28
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:45:28
CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-28 14:45:28
CTS FIX: Sending the Logon message. | 2019-01-28 14:45:29
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:45:29 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:41:12.35745=1372=A373=1058=Sending Time Accuracy problem10=195 | 2019-01-28 14:45:29 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:45:29 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:41:12.35858=Received unauthorized messages while not logged in10=220 | 2019-01-28 14:45:29 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:45:29
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:45:29
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:45:29
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:45:29
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:45:29
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:45:29
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:29
CTS FIX socket (1) | Closed. | 2019-01-28 14:45:29
CTS T4 FIX | Disconnected. | 2019-01-28 14:45:29
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:29
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:45:32
CTS T4 FIX | Firm: PTP | 2019-01-28 14:45:32
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:45:32
CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-28 14:45:32
CTS FIX: Sending the Logon message. | 2019-01-28 14:45:32
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:45:33 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:41:16.49345=1372=A373=1058=Sending Time Accuracy problem10=200 | 2019-01-28 14:45:33 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:45:33 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:45:33
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:41:16.49358=Received unauthorized messages while not logged in10=224 | 2019-01-28 14:45:33 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:45:33
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:45:33
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:45:33
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:45:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:45:33
CTS FIX socket (1) | Closed. | 2019-01-28 14:45:33
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:33
CTS T4 FIX | Disconnected. | 2019-01-28 14:45:33
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:33
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:45:36
CTS T4 FIX | Firm: PTP | 2019-01-28 14:45:36
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:45:36
CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-28 14:45:36
CTS FIX: Sending the Logon message. | 2019-01-28 14:45:37
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:45:37
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:45:37 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:41:20.60245=1372=A373=1058=Sending Time Accuracy problem10=187 | 2019-01-28 14:45:37 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:45:37 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:41:20.60358=Received unauthorized messages while not logged in10=212 | 2019-01-28 14:45:37 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:45:37
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:45:37
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:45:37
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:45:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:45:37
CTS FIX socket (1) | Closed. | 2019-01-28 14:45:37
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:37
CTS T4 FIX | Disconnected. | 2019-01-28 14:45:37
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:37
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:45:40
CTS T4 FIX | Firm: PTP | 2019-01-28 14:45:40
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:45:40
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:45:40
CTS FIX: Sending the Logon message. | 2019-01-28 14:45:41
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:45:41 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:41:24.52645=1372=A373=1058=Sending Time Accuracy problem10=196 | 2019-01-28 14:45:41 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:45:41 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:41:24.52658=Received unauthorized messages while not logged in10=220 | 2019-01-28 14:45:41 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:45:41
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:45:41
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:45:41
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:45:41
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:45:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:45:41
CTS FIX socket (1) | Closed. | 2019-01-28 14:45:41
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:41
CTS T4 FIX | Disconnected. | 2019-01-28 14:45:41
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:41
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:45:44
CTS T4 FIX | Firm: PTP | 2019-01-28 14:45:44
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:45:44
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:45:44
CTS FIX: Sending the Logon message. | 2019-01-28 14:45:45
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:45:45 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:41:28.34145=1372=A373=1058=Sending Time Accuracy problem10=195 | 2019-01-28 14:45:45 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:45:45 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:45:45
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:41:28.34158=Received unauthorized messages while not logged in10=219 | 2019-01-28 14:45:45 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:45:45
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:45:45
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:45:45
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:45:45
CTS FIX socket (1) | Closed. | 2019-01-28 14:45:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:45:45
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:45
CTS T4 FIX | Disconnected. | 2019-01-28 14:45:45
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:45
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:45:48
CTS T4 FIX | Firm: PTP | 2019-01-28 14:45:48
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:45:48
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:45:48
CTS FIX: Sending the Logon message. | 2019-01-28 14:45:48
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:45:49 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:41:32.09845=1372=A373=1058=Sending Time Accuracy problem10=199 | 2019-01-28 14:45:49 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:45:49 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:41:32.09858=Received unauthorized messages while not logged in10=223 | 2019-01-28 14:45:49 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:45:49
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:45:49
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:45:49
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:45:49
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:45:49
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:45:49
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:49
CTS FIX socket (1) | Closed. | 2019-01-28 14:45:49
CTS T4 FIX | Disconnected. | 2019-01-28 14:45:49
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:49
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:45:52
CTS T4 FIX | Firm: PTP | 2019-01-28 14:45:52
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:45:52
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:45:52
CTS FIX: Sending the Logon message. | 2019-01-28 14:45:52
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:45:53 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:41:35.99345=1372=A373=1058=Sending Time Accuracy problem10=206 | 2019-01-28 14:45:53 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:45:53 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:45:53
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:41:35.99358=Received unauthorized messages while not logged in10=230 | 2019-01-28 14:45:53 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:45:53
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:45:53
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:45:53
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:45:53
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:45:53
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:53
CTS FIX socket (1) | Closed. | 2019-01-28 14:45:53
CTS T4 FIX | Disconnected. | 2019-01-28 14:45:53
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:53
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:45:56
CTS T4 FIX | Firm: PTP | 2019-01-28 14:45:56
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:45:56
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:45:56
CTS FIX: Sending the Logon message. | 2019-01-28 14:45:56
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:45:56 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:41:39.75045=1372=A373=1058=Sending Time Accuracy problem10=201 | 2019-01-28 14:45:56 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:45:56 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:45:56
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:41:39.75058=Received unauthorized messages while not logged in10=225 | 2019-01-28 14:45:56 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:45:56
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:45:56
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:45:56
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:45:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:45:56
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:56
CTS FIX socket (1) | Closed. | 2019-01-28 14:45:56
CTS T4 FIX | Disconnected. | 2019-01-28 14:45:56
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:45:56
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:45:59
CTS T4 FIX | Firm: PTP | 2019-01-28 14:45:59
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:45:59
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:45:59
CTS FIX: Sending the Logon message. | 2019-01-28 14:46:00
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:46:01
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:46:01 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:41:43.82745=1372=A373=1058=Sending Time Accuracy problem10=201 | 2019-01-28 14:46:01 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:46:01 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:46:01
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:46:01
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:46:01
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:46:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:46:01
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:46:01
CTS FIX socket (1) | Closed. | 2019-01-28 14:46:01
CTS T4 FIX | Disconnected. | 2019-01-28 14:46:01
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:46:01
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:46:04
CTS T4 FIX | Firm: PTP | 2019-01-28 14:46:04
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:46:04
CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-28 14:46:04
CTS FIX: Sending the Logon message. | 2019-01-28 14:46:04
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:46:04
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:46:04
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:46:04
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:46:04
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:46:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:46:04
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:46:04
CTS FIX socket (1) | Closed. | 2019-01-28 14:46:04
CTS T4 FIX | Disconnected. | 2019-01-28 14:46:04
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:46:04
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:46:07
CTS T4 FIX | Firm: PTP | 2019-01-28 14:46:07
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:46:07
CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-28 14:46:07
CTS FIX: Sending the Logon message. | 2019-01-28 14:46:08
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:46:08 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:41:51.45145=1372=A373=1058=Sending Time Accuracy problem10=193 | 2019-01-28 14:46:08 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:46:08 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:46:08
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:41:51.45158=Received unauthorized messages while not logged in10=217 | 2019-01-28 14:46:08 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:46:08
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:46:08
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:46:08
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:46:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:46:08
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:46:08
CTS FIX socket (1) | Closed. | 2019-01-28 14:46:08
CTS T4 FIX | Disconnected. | 2019-01-28 14:46:08
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:46:08
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:46:11
CTS T4 FIX | Firm: PTP | 2019-01-28 14:46:11
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:46:11
CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-28 14:46:11
CTS FIX: Sending the Logon message. | 2019-01-28 14:46:12
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:46:12 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:46:12
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:41:55.23045=1372=A373=1058=Sending Time Accuracy problem10=192 | 2019-01-28 14:46:12 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:46:12 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:41:55.23158=Received unauthorized messages while not logged in10=217 | 2019-01-28 14:46:12 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:46:12
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:46:12
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:46:12
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:46:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:46:12
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:46:12
CTS FIX socket (1) | Closed. | 2019-01-28 14:46:12
CTS T4 FIX | Disconnected. | 2019-01-28 14:46:12
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:46:12
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:46:15
CTS T4 FIX | Firm: PTP | 2019-01-28 14:46:15
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:46:15
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:46:15
CTS FIX: Sending the Logon message. | 2019-01-28 14:46:15
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:46:16 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:41:59.15445=1372=A373=1058=Sending Time Accuracy problem10=201 | 2019-01-28 14:46:16 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:46:16 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:46:16
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:41:59.15458=Received unauthorized messages while not logged in10=225 | 2019-01-28 14:46:16 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:46:16
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:46:16
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:46:16
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:46:16
CTS FIX socket (1) | Closed. | 2019-01-28 14:46:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:46:16
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:46:16
CTS T4 FIX | Disconnected. | 2019-01-28 14:46:16
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:46:16
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:46:19
CTS T4 FIX | Firm: PTP | 2019-01-28 14:46:19
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:46:19
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:46:19
CTS FIX: Sending the Logon message. | 2019-01-28 14:46:19
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:46:20 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:42:02.91145=1372=A373=1058=Sending Time Accuracy problem10=191 | 2019-01-28 14:46:20 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:46:20 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:46:20
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:42:02.91258=Received unauthorized messages while not logged in10=216 | 2019-01-28 14:46:20 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:46:20
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:46:20
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:46:20
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:46:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:46:20
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:46:20
CTS FIX socket (1) | Closed. | 2019-01-28 14:46:20
CTS T4 FIX | Disconnected. | 2019-01-28 14:46:20
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:46:20
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:46:23
CTS T4 FIX | Firm: PTP | 2019-01-28 14:46:23
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:46:23
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:46:23
CTS FIX: Sending the Logon message. | 2019-01-28 14:46:23
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:46:23 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:46:23
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:42:06.74745=1372=A373=1058=Sending Time Accuracy problem10=202 | 2019-01-28 14:46:23 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:46:23 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:42:06.74758=Received unauthorized messages while not logged in10=226 | 2019-01-28 14:46:23 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:46:23
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:46:23
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:46:23
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:46:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:46:23
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:46:23
CTS FIX socket (1) | Closed. | 2019-01-28 14:46:23
CTS T4 FIX | Disconnected. | 2019-01-28 14:46:23
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:46:23
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:48:23
CTS T4 FIX | Firm: PTP | 2019-01-28 14:48:23
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:48:24
CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 14:48:24
CTS FIX: Sending the Logon message. | 2019-01-28 14:48:25
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:48:25 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:44:08.43445=1372=A373=1058=Sending Time Accuracy problem10=199 | 2019-01-28 14:48:25 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:48:25 *
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:44:08.43458=Received unauthorized messages while not logged in10=223 | 2019-01-28 14:48:25 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:48:25
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:48:25
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:48:25
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:48:25
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:48:25
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:48:25
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:48:25
CTS FIX socket (1) | Closed. | 2019-01-28 14:48:25
CTS T4 FIX | Disconnected. | 2019-01-28 14:48:25
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:48:25
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 14:50:25
CTS T4 FIX | Firm: PTP | 2019-01-28 14:50:25
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 14:50:26
CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-28 14:50:26
CTS FIX: Sending the Logon message. | 2019-01-28 14:50:26
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-28 14:50:27 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190128-14:46:10.15345=1372=A373=1058=Sending Time Accuracy problem10=192 | 2019-01-28 14:50:27 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-28 14:50:27 *
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 14:50:27
FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190128-14:46:10.15358=Received unauthorized messages while not logged in10=216 | 2019-01-28 14:50:27 *
CTS FIX socket (1) | Max send buffers used during socket life: 1 | 2019-01-28 14:50:27
CTS FIX socket (1) | Signaling to core to close socket | 2019-01-28 14:50:27
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-28 14:50:27
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 14:50:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 14:50:27
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:50:27
CTS FIX socket (1) | Closed. | 2019-01-28 14:50:27
CTS T4 FIX | Disconnected. | 2019-01-28 14:50:27
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 14:50:27
[2019-01-28 15:28:04]
Sierra Chart - Max - Posts: 5779
The issue seem to be related to your clock being off:
Notice: Your computer's clock is off by 256 seconds. For help with this, press the 'Send for Analysis' button. | 2019-01-28 14:40:34
Select Global Settings >> Set System Date-Time from Server from the Sierra Chart menu to fix your clock.
Refer to help topic 38:
http://www.sierrachart.com/index.php?page=doc/helpdetails38.html
Sierra Chart Support
