Date/Time: Fri, 24 Jan 2025 14:30:58 +0000
Fix protocol
View Count: 686
[2019-01-28 15:05:01] |
Gyuri - Posts: 2 |
Dear Support, I am interested in automated trading using Sierra's data, and would like use fix protocol instead of DTC. Can you please provide some technical info how to proceed? Thank you, Gyorgy |
[2019-01-28 17:14:00] |
There is no support for the FIX protocol for market data that Sierra Chart provides through its own server. There are many encodings already supported and they are documented here: DTC Protocol: Message Format and Encoding Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
