Date/Time: Wed, 19 Mar 2025 19:10:23 +0000
Show Order Fills Box Color
View Count: 1753
[2019-01-28 14:43:29] |
CLscalper - Posts: 28 |
This is probably a simple one, how do I change the color on the chart trading "Show Order Fills" box? It is currently dark purpleish with black text. |
[2019-01-28 21:26:18] |
This is explained in the documentation here: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart Also refer to the Graphics Settings starting here: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart Trading Order Fill Buy Entry We can see the text color is not controllable but we will add a new color setting for that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-28 21:27:23
[2022-10-28 00:12:42] |
User132988 - Posts: 13 |
Is there a way for the entry/exit colors to code, based off P/L? IE only show green on the exit, if the Profit was positive? |
[2022-10-28 14:16:39] |
John - SC Support - Posts: 38806 |
There is not the ability to do this for the fill markers themselves. But, there is the ability to define the Connecting Line between the fills to be based on the P/L. Refer to the following: Global Trade Settings Windows: Color Connecting Lines Based on Profit/Loss (Global Settings >> Chart Trade Settings >> Order Fills >> Order Fills) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-10-29 01:15:11] |
OK thanks, did see that option but not exactly what I was hoping for. No problems, thank you!
