Date/Time: Fri, 24 Jan 2025 14:49:17 +0000
I have a footprint chart up but I don't have a ticks on it?
View Count: 565
[2019-01-28 14:12:57]
User384325 - Posts: 1
Hi'
I have a footprint chart working along with the DOM but I don't have any ticks on the footprint chart?
I looked through the forum notes and could not find anything.
Do I need to upgrade?
Regards Will
[2019-01-28 17:15:52]
Is the chart blank? Also login to this support board with the account you are using with Sierra Chart. To do that select Help >> Support Board. Do that before responding. The account that you are using is currently expired.
Date Time Of Last Edit: 2019-01-28 17:16:08
