Date/Time: Mon, 27 Jan 2025 04:39:14 +0000
WriteBarAndStudyDataToFile source code
View Count: 856
[2019-01-28 12:59:01]
User942837 - Posts: 108
Where can I find the source code of sc.WriteBarAndStudyDataToFile please?
[2019-01-28 19:34:27]
John - SC Support - Posts: 37478
It is in the Studies6.cpp file located in the ACS_Source directory under the main Sierra Chart installation.
[2019-01-28 19:40:35]
yes I know but you are referring to scsf_WriteBarAndStudyDataToFile. That function is calling sc.WriteBarAndStudyDataToFile on the last line. I want the code in that function please because it calls the studies and outputs them.
Date Time Of Last Edit: 2019-01-28 19:40:51
[2019-01-28 19:52:10]
Sorry, I did not recognize that.
Unfortunately, that source code is not available, as it is an internal function.
[2019-01-28 20:01:10]
so there is no way I can modify that code?
[2019-01-28 20:10:14]
No that is not modifiable.
[2019-01-28 20:14:25]
i need a way to add columns. How do u suggest to proceed please?
[2019-02-01 16:00:02]
Pls I need code to be able to export all studies in csv and be able to modify code? Can you please release it somewhere? This is really stopping me!
Thank you
