Date/Time: Fri, 24 Jan 2025 18:32:36 +0000
[User Discussion] - TPO & VbP Difference in VA
View Count: 842
[2019-01-27 13:50:57]
User590016 - Posts: 50
As the TPO and the VbP might have a difffernt Value area, is it possible to draw their difference as a zone on the chart automatically?
At the moment I have a different coloring for both the Vbp and TPO to distinguish them but it would be easier with an option to just draw the difference.
[2019-01-28 21:56:47]
You would need to use the TPO Value Area and Volume Value Area studies, and then it depends on how you want to visualize the difference. If, for example, you want to fill in the area between the two High values, then you would use the Study Subraphs Reference and use one of the fill options (like Fill Top/Fill Bottom) which will color in the area between the lines.
Refer to the following for the TPO Value Area Lines Study:
Refer to the following for the Volume Value Area Lines Study:
Refer to the following for the Study Subgraphs Reference study:
And refer to the following for how to set the Draw Style to fill in an area:
Chart Studies: Filling the Area Between Two Study Subgraphs within Same Study
[2019-01-29 06:23:13]
I want to draw the upper difference (exceeding difference between the 2 Value Areas) as a rectangle as it will act as a resistance level and I want to draw the lower area (exceeding difference between the 2 Value Areas) as a rectangle as well which will act as a support.
I am joining an example with the zones drawn manually. I have to refer to the TPO and Vb because if I split the TPO then the modification need to change as well. And the specific VA studies cannot be split.Thanks
Date Time Of Last Edit: 2019-01-29 14:40:13
imageTPOVolProfileCharts_NumberedElements.png / V - Attached On 2019-01-29 06:43:04 UTC - Size: 48.89 KB - 297 views
