Date/Time: Fri, 24 Jan 2025 14:45:29 +0000
Suupport Please add round to the nearest tick for
View Count: 687
[2019-01-27 06:38:59] |
User508140 - Posts: 9 |
Highest High/Lowest Low over # of bars. Thanks |
[2019-01-28 21:53:49] |
There is universal support for this with this particular study: Round Study Subgraph to Tick Size Also refer to: Study Subgraph In Ticks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-28 21:54:28
