Date/Time: Fri, 24 Jan 2025 14:33:17 +0000
[User Discussion] - CROSSFROMBELOW Formula Errors
View Count: 1130
[2019-01-27 03:14:29] |
User348651 - Posts: 3 |
Hi guys, I am trying to follow a tutorial on setting up basic MA crossover buy/sell alerts, however I get the following error: Error: SYNTAX! | Formula: = *CROSSFROMBELOW(ID5.SG1,1D6.SG1) ID5 = MA1 ID6 = MA2 It seems simple enough, but I can not see where the syntax error is, and I have entered it verbatim to the tutorial... Any ideas would be great. Screenshot attached. https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=25497 |
formula error.JPG / V - Attached On 2019-01-27 03:12:42 UTC - Size: 64.69 KB - 484 views |
[2019-01-27 04:16:17] |
Sawtooth - Posts: 4162 |
The syntax you are using is only for Simple Alerts. And it contains an error. It should be: =CROSSFROMBELOW(ID5.SG1,ID6.SG1) The syntax for spreadsheets requires a range comparison and row references: =CROSSFROMBELOW(ID5.SG1@3:ID5.SG1@4,ID6.SG1@3:ID6.SG1@4) |
[2019-01-27 05:31:36] |
thank you, the first one seems to have fixed it
[2019-01-27 15:40:36] |
User875891 - Posts: 63 |
Ive done the same thing 100 times substituting an (1) for a (I) in the ID |
