Date/Time: Sat, 01 Mar 2025 07:55:53 +0000
TrendLine Studies
View Count: 1954
[2019-01-26 23:30:51]
a Gem Tree - Posts: 60
I had asked about Trendline studies a few months back.
Since there is a horizontal line study, which allows users to manually place horizontal lines and then reference them with alerts, alert studies, and automated trading spreadsheets...
Perhaps SC could create Trendlines which could be set manually and referenced by other studies.
You had said this would be something you might work on...
Is that still the case?
[2019-01-29 05:42:29]
Yes we plan to add enhancements regarding this functionality, we have just not yet gotten to it.
[2019-06-09 08:56:27]
User556932 - Posts: 31
Hi SC,
I notice that using the Chart Drawing Alert, you can set an alert for a manually drawn line or ray. It would be great if it were possible to Auto trade from a manually drawn line (eg a trend line)
Following from the question by "a Gem Tree" [2019-01-26 23:30:51] are you in a position to advise when you might looking at enhancing the functionality to allow this?
Thanks in advance for your reply.
[2021-09-28 14:47:15]
User230940 - Posts: 121
Hello SC,
did you add a Trendline Study as the horizontal line Study?
regards
carsten
[2021-09-28 16:15:56]
John - SC Support - Posts: 38292
Nothing has been done with this yet.
[2021-09-29 08:32:06]
and it is not planed?
[2021-09-29 14:25:12]
It is not specifically planned for, it is one of these items that if we get time, we will take a look and implement it. There are just other priorities at the moment.
