Date/Time: Fri, 24 Jan 2025 14:37:36 +0000
[Programming Help] - Cryptocurrency Trade Support
View Count: 1126
[2019-01-26 16:41:26] |
BlakJak - Posts: 108 |
Hi, I saw that only BitMEX is supported. Is there a plan for Deribit to be supported? If this is going to take some time, is there anyway to create a custom trade connection for Sierra Charts? |
[2019-01-28 21:55:06] |
No there are no plans for Deribit for trading. You can use the DTC service client in Sierra Chart to connect to a DTC server which would have to be developed to do this: Data and Trading Communications (DTC) Protocol Test Client Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-28 21:55:51
