Date/Time: Fri, 24 Jan 2025 14:48:04 +0000
How to skip weekend replay?
View Count: 890
[2019-01-26 11:30:04]
User517260 - Posts: 97
Dear Support, how I may skip weekend testing during replay of chart? I used check box "Skip Empty periods" but it does not work. How I may tune replayer to avoid testing of weekend empty data? Thanks. Alex.
[2019-01-28 21:52:02]
Do you see the weekend data in the chart? It sounds like it is not there because you refer to it as "weekend empty data".
And refer to this documentation here:
Replaying Charts: Automatic Skipping of Periods Where There Is No Trading and Synchronization
[2019-01-28 22:01:33]
Hi! No, I use option "Don't use weekend data", but I use "Charts to Replay >> All Charts in Chartbook" and "Replay Mode - Calculate Every Tick". Thanks, I will use settings to tune my replayer according to your link. Thanks a lot! Best regards, Alex.
