Date/Time: Fri, 18 Sep 2026 04:12:52 +0000
SC Hangs when adding custom study
View Count: 2483
[2013-11-12 03:29:04]
hairyMug - Posts: 31
1. add a custom study with inputs to chart
2. run bar-based backtest
3. change name of an input (in the study code)
4. recompile code
5. delete study from chart
6. try to add the study
7. SC hangs with following message:
Description:
A problem caused this program to stop interacting with Windows.
Problem signature:
Problem Event Name:  AppHangB1
Application Name:  SierraChart.exe
Application Version:  700.0.0.0
Application Timestamp:  527ff702
Hang Signature:  86a2
Hang Type:  0
OS Version:  6.1.7601.2.1.0.256.48
Locale ID:  1033
Additional Hang Signature 1:  86a291031dfa78c9345eaec1c8ceefb6
Additional Hang Signature 2:  4b95
Additional Hang Signature 3:  4b95ef3a28d29f25733f8dcd7ce62611
Additional Hang Signature 4:  86a2
Additional Hang Signature 5:  86a291031dfa78c9345eaec1c8ceefb6
Additional Hang Signature 6:  4b95
Additional Hang Signature 7:  4b95ef3a28d29f25733f8dcd7ce62611
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
[2013-11-12 03:42:39]
We do not see how we can help with a problem like this other than refer to help topic 17 here:
Http://www.sierrachart.com/index.php?l=doc/helpdetails17.html
The problem is not within Sierra Chart. It must be within the custom study.
[2013-11-12 12:27:50]
Thank you but I don't think I have explained it properly.
All the custom studies work correctly, the problem only occurs, (and not always), when the study is replaced and an input has been changed. After restarting, the study can be added or replaced with no issue.
I am thinking when the study is added, there is some registration routine in SC which attempts to map the current input variables to the new input variables, and since some of the input variable names were changed, it fails to map and then hangs.
This only started after version 1035; previous versions never did this.
I will attempt to determine the steps to reproduce 100% of the time (if possible).
[2013-11-12 17:18:40]
No, this does not happen. There should be no trouble with changing inputs and even keeping the same study on the chart.
Are you using the Sierra Chart built-in compiler? If so, we will test this.
Date Time Of Last Edit: 2013-11-12 17:19:34
[2013-11-23 18:24:59]
This problem is now more frequent and has nothing to do with compiling...
it occurs after changing the inputs and backtesting multiple times.
There are now two crash messages.
The first:
Problem signature:
Problem Event Name:  APPCRASH
Application Timestamp:  528ffdfb
Fault Module Name:  MSVCR100.dll
Fault Module Version:  10.0.40219.325
Fault Module Timestamp:  4df2be1e
Exception Code:  c0000005
Exception Offset:  0001d3d5
Locale ID:  1033
Additional Information 1:  0a9e
Additional Information 2:  0a9e372d3b4ad19135b953a78882e789
Additional Information 3:  0a9e
Additional Information 4:  0a9e372d3b4ad19135b953a78882e789
And Then another message:
Problem signature:
Fault Module Name:  ntdll.dll
Fault Module Version:  6.1.7601.18229
Fault Module Timestamp:  51fb1072
Exception Code:  c015000f
Exception Offset:  0008482b
Locale ID:  1033
Additional Information 1:  e520
Additional Information 2:  e5203e0497da4635e246293afbe96216
Additional Information 3:  dcd2
Additional Information 4:  dcd2c6bc307c58e912c27eed76ef9a8d
Note: I am running the latest version (1051) and my system has all SSDs and not disk drives...
Hopefully this will give a clue as to where things are failing...
>> I will also attempt re-compiling using the SC compiler but I don't have much hope that it will change anything.
[2013-11-23 21:39:32]
This can only be coincidental. It could not in and of itself be the cause of the problem.
It is entirely possible your custom study is causing a memory corruption and then causing this problem at a later point in time. We do not see how we can help with this problem. If there was something wrong with what happens when Add Custom Study is used, we would have widespread reports of this. While certainly we do periodically have reports of problems with that, It is always because of a faulty DLL file or some bug with it.
One suggestion is make sure you have a return statement at the bottom of every sc.SetDefaults code block.
