Date/Time: Fri, 24 Jan 2025 14:35:09 +0000
Importing tick data
View Count: 1107
[2019-01-25 15:42:32] |
User288945 - Posts: 22 |
Hi: Can I import tick data into a spreadsheet? if so what is the column layout? What format are you looking for? Is there any limitation on how many rows of data? I would like to do this within SC spreadsheet if possible. If not I can use Access or Excel 2016. Next question: Is there something thing that provides a big picture on how data is handled in SC? for Example. Sheet one is for your studies. Sheet 2 - is daily, sheet - 3 hourly etc. down to tick level. I am trying to get a handle on how you structure spreadsheets for replay and testing trading strategies. What I am trying to do is swing trade futures. If we us ES as an example and simple moving averages, I would like to first scan for all instances of a crossover and then start at the beginning and move to a random 2 - 5 bars before first instance so I can play it as if live trading record the trade then jump to the next. The benefits are: A. I can train myself on playing trade setups as if live. B. I can test the strategy to determine profitability and refine the strategy in various markets and volatility. Is there any you tube or other material that could assist me? Thanks |
[2019-01-28 17:42:37] |
You can import tick by tick data into an Intraday data file only: Exporting and Importing Intraday Data Files Your other question is best answered by this section here: Spreadsheet Systems, Alerts and Automated Trading: Spreadsheet Calculations and Spreadsheet Study Processing of Spreadsheet Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-28 17:42:57
