Date/Time: Fri, 24 Jan 2025 14:48:57 +0000
Separate Clearing Function of Current Trades Bid-Ask-Total Vol
View Count: 668
[2019-01-25 15:14:15] |
User993067 - Posts: 156 |
Is there a way to clear the current trades Bid Ask while leaving the current trades total volume. When I clear the current B/A the total volume also clears...I would like the option to clear these separately. So I can see the total volume over a period that I am viewing and clear then clear the BA print. Is this possible?
[2019-01-25 17:45:10] |
No, this is not supported, as the Current Total Volume is simply the sum of the Current Bid and Current Ask.
