Date/Time: Fri, 24 Jan 2025 14:42:11 +0000
Bitmex position entry wrong displayed
View Count: 1099
[2019-01-25 15:09:45] |
morpheus - Posts: 3 |
Dear Support, I trade with different PCs (Laptop / Workstation), where Sierra is installed. If i open a position on bitmex on my Laptop (for example at 3650) shutdown my laptop and open Sierra on my Workstation, the entry of the position is shown at the current price. For example 3674. So Sierra is not really getting the entry of the position. Is this a general problem or do i have to setup something different? kind regards, Nils |
[2019-01-25 19:54:42] |
Refer to this section here: Trading Information Windows: How Average Price for Positions Is Calculated and Used Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
