Date/Time: Fri, 24 Jan 2025 14:33:04 +0000
Session Time Toggle via Control Bar
View Count: 1126
[2019-01-25 13:47:01] |
infpz - Posts: 826 |
Is this possible? For the active chart, click on a Control Bar button to choose a certain user-defined session time (say, 17:00 - 16:00). The click another Control Bar Button to change the existing chart to a new preset session time (say, 08:30 - 15:00).
[2019-01-25 17:40:15] |
To some extent. You can enable and disable the evening session through a control bar button: Chart Session Times: Use Evening Session (optional) (Chart >> Chart Settings >> Session Times) What you want to do, however, can be accomplished through ACSIL programming. Refer to the following section: https://www.sierrachart.com/index.php?page=doc/ACSInteractionWithMenusControlBarButtonsPointerEvents.php#ACSControlBarButtons Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-25 17:40:51
