Date/Time: Fri, 24 Jan 2025 14:47:01 +0000
How to bring a chart into focus
View Count: 1499
[2019-01-25 06:06:47] |
User94606 - Posts: 327 |
Is there a shortcut key to bring a chart in focus? I am looking for something similar to NinjaTrader "F" button located on the top right hand corner of every chart. When "F" is pressed, it brings the current price bar in focus so you don't need to use scroll bar. The Sierra Chart End button works fine if you use the horizontal scrolls and need to go back to the current price bar. However, if you use the vertical scrolling on the chart away from the price bar, the end button does not bring you back to the current price bar. |
[2019-01-25 13:43:04] |
To reset the vertical scale you need to use Chart >> Reset Scales.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-25 13:43:32
[2019-01-25 14:19:50] |
ForgivingComputers.com - Posts: 990 |
Is there a shortcut key to bring a chart in focus? I am looking for something ...[that] brings the current price bar in focus so you don't need to use scroll bar.
Double-click the vertical scale to move the current bar towards the center of the chart. |
