Date/Time: Tue, 04 Aug 2026 23:19:47 +0000
[Programming Help] - drawstyle
View Count: 922
| [2019-01-25 03:35:04] |
| User228927 - Posts: 55 |
In Spreadsheet System for Trading I was using Down Arrow to Show Sell Entry, was wondering if there was a way to adjust distance from the candlestick bars. As of now they are on top of the candlestick, no distance between arrow and candlestick.
| [2019-01-25 15:20:20] |
| Sawtooth - Posts: 4343 |
You can also do it directly in M3: =IF(yourentryconditions,C3+$J$21*2,0) This will place the Arrow Down 2 ticks above the high. |
| [2019-01-25 20:37:13] |
Ok that worked, I also have Arrow Up on Sell Exit and used this formula in n3-,If(exitconditons,D3+$J$21*5,0) but doesn't seem to be adjusting Arrow Up. It seems like it is putting the correct values in n column.
| [2019-01-25 20:42:40] |
Sorry, I see my mistake should be -$j$kj*5, thanks for help
