Date/Time: Fri, 24 Jan 2025 14:46:45 +0000
Replay issues
View Count: 586
[2019-01-24 23:46:08]
User355317 - Posts: 10
Hi. I'm having issues with replay. When i pick a date, it always defaults to 12/25/2018.
This issue started happening a couple of days ago.
Is there a way this can be fix? Can it be reset somehow? And how far can i go back in time?
Thanks.
[2019-01-25 00:35:02]
We are not sure how you are doing this: "pick a date". But if you follow through these instructions carefully, you should be able to do what you want:
Replaying Charts: Basic Chart Replay Instructions
We did some updates to the documentation as well just now.
