Date/Time: Fri, 24 Jan 2025 14:53:02 +0000
CPU exception with ACS_Source file
View Count: 724
[2019-01-24 22:11:49] |
ForgivingComputers.com - Posts: 990 |
I added a DLL name to the example file in ACS_Source/ACSILSpreadsheetInteraction.cpp and did a remote build. When I attach it to a chart I get: Warning: The Custom DLL study "ACSILSpreadsheetInteraction_64.scsf_SpreadsheetInteractionExample" has just caused a CPU exception. | 2019-01-24 17:01:23
Warning: This Custom DLL study may cause AT to be unstable until you remove the study from your chart and restart AT. | 2019-01-24 17:01:23 Am I doing something wrong? Running version 1863. |
[2019-01-25 00:37:21] |
We see the problem. It has to do with how the remote compiler is handling structure member alignment and sizes. We will solve this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-25 00:37:32
